RME Device Centre - HTTP 500 error
Oct 20th, 2009
Hi There,
Attached is the following screenshot of an HTTP 500 error I get when selecting one of my devices in the device centre.
-Device is a Cisco 1841 Integrater service router
-Am Running LMS 3.1 on Solaris
- Ran a pdshow,all services are running
Hope you are having a great day
Joe Clarke Tue, 10/20/2009 - 08:42
This error points to no available configs for this device. Try going to RME > Config Mgmt > Archive Mgmt > Sync Archive, and run a sync archive job for this router. Make sure it is successful, then try and open the config.
Joan Pelser Tue, 10/20/2009 - 13:13
hi Joe, Ive tried this, and I can see the config, I saw your suggestion in one of the other posts. what else can I try ?
Joe Clarke Tue, 10/20/2009 - 14:32
I'm confused. If you can see the config, then it's working, right?
Joan Pelser Tue, 10/20/2009 - 23:12
When accessing the configs using the following path :RME > Config Mgmt > Archive Mgmt > Sync Archive, I can see the configs, however when I go to device centre and select the device, I get the Http 500 error
Joe Clarke Wed, 10/21/2009 - 08:12
It could be that there is some archive damage for this device. Are all devices affected, or is it just this one device?
Joan Pelser Wed, 10/21/2009 - 08:28
No there are around 10 devices that ive found on a network of 500 devices.
Joe Clarke Mon, 10/26/2009 - 09:41
Try deleting one of the affected devices from RME, then re-add it. See if the problem goes away.
