Failover using static routes
Oct 20th, 2009
I have Site A and Site B connected via LAN-X.I brought in secondary LAN-X for backup purposes and tried to implement it using static routes for the fact that ONLY static routes be used to achieve failover.I have tried to unplug the PRIMARY LINK cable from switch from site B and it did not failover.please see the config below and advise..I also checked the ip route table on all switches and I did not see the route usingbackup interface.I have also tried using INTERFACE command in static route to make sure routes are deleted once the link is down but this did not help either...
Note : SWITCH-1 and SWITCH-2 are UPLINKED at SITE A
SWITCH -1 :SITE A
interface FastEthernet3/1
description PRIMARY-LAN-X
no switchport
ip address 10.100.100.1 255.255.255.248
speed 100
duplex full
end
interface Vlan90
description GroundFloor
ip address 10.32.90.2 255.255.254.0
ip helper-address 144.1.4.40
standby 10 ip 10.32.90.1
standby 10 priority 105
standby 10 preempt
interface Vlan24
ip address 10.32.0.7 255.255.252.0
standby 24 ip 10.32.0.6
standby 24 priority 105
standby 24 preempt
ip route 10.32.50.0 255.255.255.0 10.100.100.2
ip route 10.32.50.0 255.255.255.0 10.32.90.3 2(Admin Distance)
ip route 10.32.52.0 255.255.255.0 10.100.100.2
ip route 10.32.52.0 255.255.255.0 10.32.90.3 2(Admin Distance)
SWITCH -2 :SITE A
description BACKUP-LAN-X
no switchport
ip address 10.200.200.1 255.255.255.248
ip policy route-map ToStoresVia3000
speed 100
duplex full
end
interface Vlan90
ip address 10.32.90.3 255.255.254.0
standby 10 preempt
interface Vlan24
ip address 10.32.0.8 255.255.252.0
standby 24 preempt
ip route 10.100.100.0 255.255.255.248 10.32.90.2
ip route 10.32.50.0 255.255.255.0 10.32.90.2
ip route 10.32.50.0 255.255.255.0 10.200.200.2 2(Admin Distance)
ip route 10.32.52.0 255.255.255.0 10.32.90.2
ip route 10.32.52.0 255.255.255.0 10.200.200.2 2(Admin Distance)
SWITCH -3 : SITE B
interface GigabitEthernet1/0/24
description PRIMARY-LanX
no switchport
ip address 10.100.100.2 255.255.255.248
speed 100
duplex full
interface GigabitEthernet2/0/1
no switchport
ip address 10.200.200.2 255.255.255.248
speed 100
duplex full
Interface Vlan5
description Server VLAN
ip address 10.32.50.1 255.255.255.0
interface Vlan52
description LAN/WAN Admin VLAN
ip address 10.32.52.1 255.255.255.0
ip helper-address 10.32.50.10
ip route 0.0.0.0 0.0.0.0 10.100.100.1
ip route 0.0.0.0 0.0.0.0 10.200.200.1 2(Admin Distance)
Giuseppe Larosa Tue, 10/20/2009 - 09:07
  • Hall of Fame,
    Founding Member
depending on how the sites are interconnected (=if there is anything in between a switch or firewall) you may need to add some intelligence and to use reliable static routing to check reachability of IP next-hop of primary route.
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
more specifically
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1070516
real implementation of the probe depends on IOS version
if the cable is direct unplugging should make the interface on the other side to go down.
Then the ARP entry for IP next-hop should be removed and also the static route.
Hope to help
Giuseppe
CCDECCDE9 Tue, 10/20/2009 - 13:30
The connections are point to point and nothing in between.I am at IOS 12.2(18).I have done this before with routers and it worked and this time these are layer-3 switches.And how did we do this redundancy before this IP SLA came out and ALSO what is the advantage of using Admin Distance with static routes .Thanks
vmiller Tue, 10/20/2009 - 14:09
  • Gold, 750 points or more
When you test, do you see the link go into a down status? Some metro type services will keep layer 1 &2 up even though layer 3 is down. One method I have used is to point to an interface instead of an address for next hop.
By adding an admin distance to the backup route, you make it less preferred than the primary. once the primary goes down, its AD goes to 255...the the one at 2 is more preferred.
CCDECCDE9 Tue, 10/20/2009 - 17:23
I did not check because I unplugged the cable and was checking routes all the time to see if the routing table changes with new next hop..
