regular translation creation failed for protocol 50
Answered Question
Oct 20th, 2009
I get the following error when trying to connect a vpn client through an ASA5505 with an already configured ipsec AES/256 site to site connection:
regular translation creation failed for protocol 50 src:inside:192.168.1.167
dst:outside:xx.xxx.x.64
The site to site addressing is not relevant, I'm not trying to pass traffic over the site-to-site, but rather create a new vpn from inside client to outside external vpn box that's not under my control.
The client is able to create a connection, but no traffic is passed, when I try to ping / rdp, the above message is returned to me.
If I add the rule static(inside, outside) interface 192.168.1.167 netmask 255.255.255.255 then it works, everyting works, but ONLY from this computer.
Been googling for hours, but with no result as of yet.
Hope someone can shed some light over my issues.
\\mark
Correct Answer by JORGE RODRIGUEZ about 7 years 5 months ago
Hi, have the far end client running the VPN server to enable NAT-T, if they have a PIX/ASA have then add crypto isakmp nat-traversal 20 just like you do have in yours.
Overall Rating: 5 (1 ratings)
markraves Tue, 10/20/2009 - 04:22
Config pasted:
unimportant stuff cut.
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password cVAXXXX/XXXXXX encrypted
passwd cVXXXX/XXXXmY encrypted
names
interface Vlan2
nameif inside
security-level 100
interface Vlan3
nameif outside
security-level 0
ip address 195.1.xx.xxx 255.255.255.252
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
mtu inside 1500
mtu outside 1500
arp timeout 14400
global (inside) 1 interface
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.1.0 255.255.255.0
access-group portforw in interface outside
route outside 0.0.0.0 0.0.0.0 195.1.xx.xxx 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 193.213.xxx.xx
crypto map outside_map 1 set transform-set ESP-AES-256-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 9
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
dhcpd auto_config inside
group-policy DfltGrpPolicy attributes
banner none
wins-server none
dns-server none
dhcp-network-scope none
vpn-access-hours none
vpn-simultaneous-logins 3
vpn-idle-timeout 30
vpn-session-timeout none
vpn-filter none
vpn-tunnel-protocol IPSec
password-storage disable
ip-comp disable
re-xauth disable
group-lock value 193.213.xxx.xx
pfs disable
ipsec-udp disable
ipsec-udp-port 10000
split-tunnel-policy tunnelspecified
split-tunnel-network-list value outside_2_cryptomap
default-domain none
split-dns none
intercept-dhcp 255.255.255.255 disable
secure-unit-authentication disable
user-authentication disable
user-authentication-idle-timeout 30
ip-phone-bypass disable
leap-bypass disable
nem disable
backup-servers keep-client-config
msie-proxy server none
msie-proxy method no-modify
msie-proxy except-list none
msie-proxy local-bypass disable
nac disable
nac-sq-period 300
nac-reval-period 36000
nac-default-acl none
address-pools none
smartcard-removal-disconnect enable
client-firewall none
client-access-rule none
webvpn
functions url-entry
html-content-filter none
homepage none
keep-alive-ignore 4
http-comp gzip
filter none
url-list none
customization value DfltCustomization
port-forward none
port-forward-name value Application Access
sso-server none
deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information
svc none
svc keep-installer installed
svc keepalive none
svc rekey time none
svc rekey method none
svc dpd-interval client none
svc dpd-interval gateway none
svc compression deflate
tunnel-group 193.213.xxx.xx type ipsec-l2l
tunnel-group 193.213.xxx.xx ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns preset_dns_map
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect pptp
inspect esmtp
inspect ipsec-pass-thru
markraves Tue, 10/20/2009 - 04:25
destination ip..
Forgot, the destination IP address (vpn-client-to-external-box network) is 192.168.50.4
Correct Answer
JORGE RODRIGUEZ Tue, 10/20/2009 - 09:16
  • Green, 3000 points or more
JORGE RODRIGUEZ Tue, 10/20/2009 - 13:53
Martin, is your issue resolved? does far end have NAT-T enabled.. did you try test RA to client without using static nat at your end.
regards
markraves Wed, 10/21/2009 - 23:53
Sorry for not following up yesterday, I couldn't check it, didn't dare stray out of my apartement. Bloody sick. And there were noone I could send over to test.
But today I'm all better and have had a chance to test it out! And it works. it just works. Fantastic. Thanks a lot;=)
\\mark
rchudasama Tue, 10/25/2011 - 08:56
Jorge I have the same issue but unfortunately clients on far end are not willing to change configuration on their PIX/VPN appliance. Is there is any otherways to solve this issue?
Rajesh
