ASA login
Oct 20th, 2009
Dear all,
When i lelnet to mu ASA:
It gives me the
username and the password prompt, after i correctly typed them, the ASA gives me again the
username and the password prompt.. and so on.
When i restart the applaince, it accept the username and the password, but, when left for a while and try to telnet to it again , same problem happen again.
I confused from this issue, as it enfore me to console only the ASA however the username and the password are typped correctly
francisco_1 Tue, 10/20/2009 - 04:30
What are you using for authentication? T Are you using TACACS or RADIUS?
Ahmed Yassin Tue, 10/20/2009 - 05:02
Sorry, i solved by cancel the aaa authentication.
Thx a lot for your help
