No ASDM access
marcus-barros
I have an ASA5505 with 8.2.1 firmware version and 6.2.1 ASDM version. I cannot access the firewall using HTTPS (ASDM). When I try to access it from IE, the message "The page cannot be displayed" is returned. When I try to acccess it from Mozilla, the message "Fail on secure connection. Error code: ssl_error_no_cypher_overlap". I have already enabled the http server and created an access-list (http ip mask if). I believe that the issue is something about the certificate and already tried to generate some one, but the problem persists.
francisco_1
Level 7
Level 7
try removing the certificate, changing the hostname of the ASA to match the host name for the trustpoint/certificate, then re-creating the certificate
I did this process again and the problem persists. I did the following process:
hostname(config)# crypto key zeroize rsa default
WARNING: The default key pair will be removed
WARNING: All device digital certificates issued using these keys will also be removed and
the associated trustpoints may not function correctly.
Do you really want to remove these keys? [yes/no]: yes
hostname(config)# show crypto key mypubkey rsa
Key pair was generated at: 12:51:49 BRST Oct 21 2009
Key name: .server
Usage: Encryption Key
Modulus Size (bits): 768
Key Data:
hex-data certificate
hostname(config)# hostname test
test(config)# crypto key generate rsa label domain modulus 1024
INFO: The name for the keys will be: domain
Keypair generation process begin. Please wait...
test(config)# show crypto key mypubkey rsa
Key pair was generated at: 12:59:15 BRST Oct 21 2009
Key name: domain
Usage: General Purpose Key
Modulus Size (bits): 1024
Key Data:
Key pair was generated at: 13:00:08 BRST Oct 21 2009
Key name: .server
Modulus Size (bits): 640
Key Data:
test(config)# crypto ca trustpoint test
test(config-ca-trustpoint)# keypair domain
test(config-ca-trustpoint)# subject-name CN=test.domain
test(config-ca-trustpoint)# enrollment self
test(config)# crypto ca enroll test
% The fully-qualified domain name in the certificate will be: test.domain
% Include the device serial number in the subject name? [yes/no]: yes
Generate Self-Signed Certificate? [yes/no]: yes
test(config)# show crypto ca certificates
Certificate
Status: Available
Certificate Serial Number: hex-data certificate serial number
Certificate Usage: General Purpose
Public Key Type: RSA (1024 bits)
Issuer Name:
serialNumber=serial-number
hostname=test.domain
cn=test.domain
Subject Name:
cn=test.domain
Validity Date:
start date: 13:08:55 BRST Oct 21 2009
end date: 12:08:55 BRST Oct 19 2019
Associated Trustpoints: test
test(config)#
The message that I received in Firefox before happened when the firewall was without a certificate. Now, I received the message that wasn't possible open a secure connection because the security protocol is not activated, but the SSL and TLS are activated in IE and Firefox. IE presents the same message before. I have the same problem with another ASA 5505, but I have, too, two ASA 5510 and this problem doesn't happen with them.
