WLC 5.2.193.0 with WCS 6.0.132.0 a supported config?
Oct 20th, 2009
  • Bronze, 100 points or more
I know of a large site (not one of mine) that is running WLC 5.2.193.0 code paired up with WCS 6.0.132.0. The release notes for each product make no mention of support for this configuration.
Is this is supported configuration?
cchitwood1 Tue, 10/20/2009 - 07:24
WCS will support up to two versions of previous controller code from the "preferred" controller version.
The two versions should not be an issue.
Robert.N.Barrett_2 Tue, 10/20/2009 - 07:28
Thanks, but I believe the problem is due to the fact that WCS 6.0.132.0 was released on June 11, 2009, which is before WLC 5.2.193.0 was released (on June 25, 2009).
Rob Huffman Tue, 10/20/2009 - 07:27
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Robert,
The reason you don't see support for 5.2.193.0 (June 25, 2009) is that it was released after the WCS release notes came out (June 11, 2009)
You should be good to go here :)
Cheers!
Rob
Robert.N.Barrett_2 Tue, 10/20/2009 - 07:43
Thanks to both of you who replied. I just need to ensure that Cisco will support this scenario. The larger site is actually a "parent" site, and we try to keep our configs in parallel, but I'm not going to put the smaller site into an unsupported configuration.
I found this document, updated September 1st, which still doesn't list WLC 5.2.193.0 and WCS 6.0.132.0 as a supported config:
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080af7140.shtml
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
