TRACER: NP failed tracing packet
Oct 20th, 2009
Hi all, I have a problem with a PIX-535 IOS 7.2(2), when we try to use the packet tracer for ASDM or CLI it dont work. On console display "TRACER: NP failed tracing packet"
Panos Kampanakis Tue, 10/20/2009 - 06:31
  • Cisco Employee,
You are probably hitting bug CSCsi59317.
And upgrade to 7.2.4 will probably get you passed it.
I hope it helps.
PK
Jeimy Galindo Tue, 10/20/2009 - 07:10
Hi, I cant see it, on the bug toolkit. you can give me a brief of this bug
Panos Kampanakis Tue, 10/20/2009 - 17:18
  • Cisco Employee,
Briefly, here it is
Packet-tracer fails to trace after about 800 packet traces. I ran a script which will execute packet-tracer command continuously. It is observed that after about 800 traces following error is seen.
asa(config)# packet-tracer input inside tcp 10.60.1.100 1800 10.60.2.72 21
asa(config)# : NP failed tracing packet
asa(config)# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(1)16
Device Manager Version 5.2(2)
It happens also for 7.2.2.
Are you in multi-context ASA? If you are there is one more defect for packet tracer.
PK
