How to Pause before sending digits out FXS port
Oct 20th, 2009
I have a H323 VG224 connected to a remote system. When i ring that port i need to pause then send some digits. I am stumped on this one. Any ideas? TIA
Chris Drew Tue, 10/20/2009 - 08:11
the key here is pause before "sending out" digits to the answering device. How do I sent digits out of an off hook FXS port
Chris Drew Tue, 10/20/2009 - 08:16
i know that to be true on FXO ports but i cant make that work on FXS. Are you sure that prefixing a pause to digits will cause the FXS port to send digits after the port has gone off hook?
