Blocking p2p connections on cisco 877w router
Oct 20th, 2009
hi,
I want to block all sorts of peer to peer connections that would be initiated by users.
I could not find a configuration guide for 877w router.
What would be the steps required to block sites like torrent etc from being accessed by users
Giuseppe Larosa Wed, 10/21/2009 - 07:30
Hello Anthic,
to verify if this can be feasible you should check if NBAR Network Based Application Recognition feature is available on your device.
read about NBAR
https://www.cisco.com/en/US/docs/ios/qos/configuration/guide/nbar_mqc_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1055125
you can use the feature navigator tool to check
www.cisco.com/go/fn
search by feature
type NBAR
choice
NBAR bittorrent PLDM
(NBAR uses special files separated from IOS for protocol definitions)
I see it for 881 or other 880 routers not for 877.
I see 877 listed for NBAR -pdlm versioning
So you may be able to configure qos policy-maps to drop or to limit peer-to-peer traffic as explained in first link above.
Hope to help
Giuseppe
