Total Output drops on switchport
Oct 20th, 2009
I have a 3750 connected to a storage device and I am seeing alot of Total output drops on the input queue
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 76207
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 31734000 bits/sec, 4366 packets/sec
5 minute output rate 37218000 bits/sec, 4632 packets/sec
1784158 packets input, 1564949850 bytes, 0 no buffer
Received 1 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
1940220 packets output, 1986930582 bytes, 0 underruns
I know you can increase the hold queue but that did not help either. I am using the lastest IOS c3750-ipservicesk9-mz.122-50.SE3. Would anyone have any suggestions ?
Thanks in advance
Yudong Wu Tue, 10/20/2009 - 08:43
  • Gold, 750 points or more
In general, output drop is caused by a busty traffic pattern. You can use the command "show platform port-asic stats drop gig x/y" to see which queue is dropping the packet. And then try to adjust your queue setting by related "mls qos queue-set output" commands.
keithannette Wed, 10/21/2009 - 03:06
Thanks for the reply. Here is the output
show platform port-asic stats drop gig 1/0/1
Interface Gi1/0/1 TxQueue Drop Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 175458
sh mls qos queue-set
Queueset: 1
Queue : 1 2 3 4
buffers : 25 25 25 25
threshold1: 100 200 100 100
threshold2: 100 200 100 100
reserved : 50 50 50 50
maximum : 400 400 400 400
Queueset: 2
Queue : 1 2 3 4
If I do sh mls-qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
What be the best way to change these settings ?
iyde Wed, 10/21/2009 - 11:54
  • Silver, 250 points or more
Hi.
First thing is to enable QoS, as it is currently disabled:
"If I do sh mls-qos
QoS is disabled"
