Cisco Works LMS 3.2 Missing fields in Device center
Oct 20th, 2009
In Device Center I am missing the following fields:
Inventory Last collected Time
Configuration Last Collected Time
As well as missing the Management tasks functions available window. I can see the data config archive in The Device Managability Status Report.
Overall Rating: 5 (1 ratings)
ppoiron Thu, 11/19/2009 - 23:58
Hi Mike,
I got the same symptoms on my LMS.
Did you fix that issue ?
Mike Mott Fri, 11/20/2009 - 08:22
Yes I did get that issue resolved with the Help of TAC. They said that I was hitting a particular bug: CSCtc21648
No idea  if you are hitting the same bug or not but here is the information that I was given.
Bug Details
RME links and info missing from Device Center after upgrade
The Resource Manager Essentials tasks and reports are missing from the Device Center. Additionally, all RME-related device information is also omitted.
This occurs after applying the RME 4.3.1 EnergyWise service pack.
A workaround is available by contacting the TAC
ppoiron Mon, 11/23/2009 - 05:56
You're right Mike.
Cisco provided me a patch which fix that issue due to RME 4.3.1 patch.
