Log report of extension mobility login/out times.
Oct 20th, 2009
We have a request for a report on logged in phones, the user wants to draw a report on the times that the phones, extension mobility, was logged in and out.
Does anyone know of an existing solution.
Overall Rating: 5 (1 ratings)
virverma Tue, 10/20/2009 - 17:16
There is as such no method currently in call manager to get this report,
I have a script that may work in CCM 4.X but its not supported by TAC or any support function,
schemberg Wed, 11/11/2009 - 03:54
You may can use the data from RTMT. With performance counters you can track logins.
Kind regards
Axel
Jamie Brown Wed, 04/28/2010 - 15:07
Not sure if you are still looking for this report, but there is an NZ/Australian company called Atea Systems who has a report of this nature running across a customer with 16000 phones.
It's not mentioned directly on the website but the company contact details are there anyway on www.ateasystems.com
Cheers
Jamie
