Collin Clark Tue, 10/20/2009 - 12:58
  • Purple, 4500 points or more
I believe that the *.pna files are proprietary, but you could try opening with notepad (check the size first). *.gz is used in linux and the app is gunzip. It's an archiver like Winzip. I believe that Winzip can extract the *.gz files.
Hope that helps.
