Broadcast Intercom?
Oct 20th, 2009
On most phone systems the intercom feature works in groups, as a paging system of sorts.
Im on UCM 6.1 and cant figure out how to do anything other than station to station intercom.
Please help.
scott.hammond Tue, 10/20/2009 - 12:21
In Avaya and Nortel if it doesnt involve an amplifier then it is still considered intercom. Though the broadcast application is more of a pager. Did a 2000 user Avaya install without a single horn or amp and did all the "paging" with the intercom feature. I just assumed the cisco's being more advanced could do the same.
Just one more of those Telecom 101 things that cisco completely dropped the ball on.
Brandon Svec Tue, 10/20/2009 - 14:28
  • Silver, 250 points or more
  • Community Spotlight Award,
    Small Business, February 2016
This probably doesn't help, but CME allows paging over the phones with no limitation. Give Cisco a chance! Seeing as they started making phones about 100 years later then Nortel, NEC and Avaya they still have some catching up to do ;)
In Cisco's defense- there is a point where some number of simultaneous voice streams will have a negative impact on nearly any network. 10/100 switches with 1000+ phones for example might not perform too well during a page.
I am curious about your Avaya install. Are you implying that you could simultaneously page 2000 IP phones at once?
Wilson Samuel Wed, 10/21/2009 - 04:44
  • Gold, 750 points or more
    Mobile User, July 2015
we use Berbee or Infromacast for that, it does makes paging broadcast paging across the phones or across the IP Speakers possible.
