Cisco CGESM switches in RME 4.3
Oct 20th, 2009
LMS3.2 on Solaris 10
I'm unable to manage in RME the Cisco CGESM switches for HpBlade Enclosure
I'm running cgesm-lanbasek9-mz.122-40.SE.bin image and RME 4.3 device
table says that is is support. Config archive works fine but inventory fails with the following error:
RICS0001:Internal Error,unable to process the collected data from the device
I ran snmpwalk and compared the results with the Cisco 3020 switch and noticed that cgesm switches are missing bunch of mibs including interface mibs. I also tried to add it in the Solarwind and it returned with the error that interface mibs are missing. Please advise.
Joe Clarke Thu, 10/22/2009 - 07:38
You are seeing CSCso45451. If you upgrade to 12.2(44)SE2 all these problems with LMS and Solar Winds should go away.
nawas Thu, 10/22/2009 - 08:26
I have one last quick question, since inventory is not collected for these switches, I will not be able to upgrade the code via CiscoWorks, correct?
Joe Clarke Thu, 10/22/2009 - 08:32
Correct. You must first do the upgrade manually to get around the bug, then you can use LMS to manage the switch moving forward.
