PIX Failover configuration
Oct 20th, 2009
Hi All,
I do not have the command "failover lan unit secondary" in the configuration.
But still i see the pix box shows as secondary.
ph-md-pix1# show failover
Failover Off
Cable status: Normal
Failover unit Secondary
Failover LAN Interface: not Configured
Unit Poll frequency 15 seconds, holdtime 45 seconds
Interface Poll frequency 15 seconds
Interface Policy 1
Monitored Interfaces 4 of 250 maximum
Let me know if any one why it is showing as secondary.
Yudong Wu Tue, 10/20/2009 - 14:07
If you are using failover cable, the primary and secondary should be decided by it.
kr_madan Tue, 10/20/2009 - 14:23
Thanks kwu2 for the information.
I wanted to conncect a cross cable between them.
can i configure lan based active/standby configuration using failover cable ?.
