ACE rate limiting question
Syed Iftekhar Ahmed Tue, 10/20/2009 - 16:21
You can either rate limit on per Vserver basis or rserver basis.
example1: rserver based rate limiting
serverfarm host syed-farm
rserver syed-server
rate-limit connection 300
example2: Vserver based rate limiting
parameter-map type connection syed-map
policy-map multi-match vlanx-vips
class VIP80
connection advanced-options syed-map
Rate limiting based on any other source or destination criteria is not supported.
One option to explore would be to use a dedicate context for a particular APP and
resource limit the connections using "limit-resource rate" command.
Netpace1/Admin(config-resource)# limit-resource rate ?
bandwidth Limit bandwidth in bytes per second
connections Limit connections per second
inspect-conn Limit rtsp/ftp inspect connections per second
mac-miss Limit mac miss traffic (punted to-the-box) in
mgmt-traffic Limit management traffic (to-the-box) in bytes per
ssl-connections Limit number of SSL connections per second
syslog Limit syslog messages per second
Syed Iftekhar Ahmed
