testeven Tue, 10/20/2009 - 14:36
  • Cisco Employee,
Hi!
You need to enable CUCM detailed SDI traces and select the Callmanager active service.
You might want to check this link:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Aslo if you have issues with an H.323 gateway, you should check debugs on the GW directly depending on the problem you have.
Teresa.
If you find this post helpful, please rate! :)
Tommer Catlin Tue, 10/20/2009 - 14:41
  • Green, 3000 points or more
Thanks Teresa. I will try that next. Sometimes I can see in CUCM where the H323 is sending the signaling from one interface, but it expects it from another, which then tells me the customer did not bind the h323 to loopback interface, etc. (or something like that)
thanks!
Nicholas Matthews Tue, 10/20/2009 - 14:55
  • Red, 2250 points or more
The source IP for that will be in hex. Ex: '0A0A0A01' is 10.10.10.1 in the H225 setup message as the 'SourceAddress' or something to that effect.
I would suggest doing a google for 'Triplecombo' or 'translatorx' for CUCM traces. It really makes them more digestable and is what a great percentage of TAC uses to analyze the traces - a couple of tools by Cisco employees.
You'll want to make sure the right check boxes are on - namely H323/H225, All Gateway, etc.
-nick
