Adding another dialer without additional hardware
Hi, We're running IPCCE 6 and we already have a dialer configured with 10 ports and I wanted to know if I could add another instance of the dialer without having to add another server (hardware) and split the ports between them.
Under the ICM Configuration Manager/Outbound Option/Dialer, I have a dialer configured as:
Dialer Name: COO1
Computer Name: XXXXXXDialer
Peripheral Name: CCM1
Ports: 10 ports
1. Can I click on the Add button and add another dialer? lets say COO2 and split the ports between them; 5 each?
2. Is this possible without adding additional hardware?
3. how would adding an additional dialer work?
4. What impact would it have on my existent configuration?
You can run the Dialer on the PG in UCCE 7.2 and later - in fact, Cisco recommend that. In the version you have, if I remember correctly, another box was stipulated.
A Dialer can have up to 96 ports. I don't see why you would want a second Dialer when you only have 10 ports. What are you trying to achieve?
