Callmanager xml analyzer
Oct 20th, 2009
Does either CM 6 or 7 have anything equivalent to the quick and dirty xml analyzer for looking at call set up or am I stuck with poring through the ccm trace.
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 10/20/2009 - 17:46
  • Cisco Employee,
  • Hall of Fame,
    2011
In the download sections for your CUCM version there is a tool called VLT (Voice Log Translator)
It helps if you have no experience reading traces or are interested in the most common messages. It does digest a good part of the trace so it's really not used for troubleshooting if that's what you want. Usually you won't see the error with it.
For troubleshooting there's nothing else than notepad and plenty of txt lines to read.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
