Translation Pattern
Answered Question
Oct 20th, 2009
My SIP provider sends me all ten digits. I am trying to configure a translation pattern that would strip all but the last four digits.
Let's say my telephone number is 281-330-8004, I would like the gateway/CUCM to ring extension 8004.
How can I properly configure this? Is it better to configure the translation pattern on the gateway or on CUCM?
Thanks!
Correct Answer by Jaime Valencia about 7 years 9 months ago
The route pattern to the SIP trunk should have the checkbox to use the external phone number mask to be used, or to place the mask on the route pattern.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
It's better to not configure any, unless you have a good reason to use a TP.
Under SIP trunk (or any GW, trunk, etc) there is a field called significant digits.
It defines how many digits from right to left CUCM should consider for routing.
Set it to 4 and only the last 4 digit will be used for routing within CUCM.
java
Overall Rating: 5 (3 ratings)
Correct Answer
Jaime Valencia Tue, 10/20/2009 - 17:49
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Brian Carlson Tue, 10/20/2009 - 19:12
I made that change, and now external callers just see the last three digits as their incoming caller-id.
For example, my number is 281-330-8004, if I call my cell phone I see a caller-id of 004. Any ideas? Thanks!
dconstantino Wed, 10/21/2009 - 05:13
Set the Mask on each phone to send 281330XXXX and it will send the number as 10 digits and the last four will be your users ext.
Or you could put in your company main number and that will be what is sent out. the sig digits will only apply to inbound.
Brian Carlson Wed, 10/21/2009 - 13:36
Is there anything else I could check? I have set my mask to 281330XXXX and it's still sending out 004 as the caller-id.
Thanks!
Correct Answer
Jaime Valencia Wed, 10/21/2009 - 13:41
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Brian Carlson Wed, 10/21/2009 - 13:45
That fixed it, I just checked "Use Calling Party's External Phone Number Mask" on the route pattern and caller-id is now working as expected.
Thanks again!
