H-REAP and SSID
Oct 20th, 2009
i have a controller that is used in normal local AP mode
and H-REAP(local switching). local AP mode is for users at the central site and
H-REAP is for the remote branch.
i created 2 SSID
Employee
Employee-H (for H-REAP)
I then use AP group to control which SSID to broadcast at the site. remote site
users will see only "Employee-H" and central site users will see "Employee"
I am just wondering is there a way i can use just one Employee SSID and still
maintain the local AP and H-REAP deployment. Using 2 SSID can be confusing to users
as they move from central to remote site and vice versa.
Is there a better way?
Eng Wee
arlincurtis Tue, 10/20/2009 - 21:01
I've got this working without AP Groups. I've got a single WLAN so just the single SSID ( I actually don't broadcast the SSID, but that's beside the point)
You need to configure that WLAN to allow H-REAP Local switching, this setting is under the advanced tab. For the central site set access points to local AP Mode, for remote sites setup access point to H-REAP AP Mode. As long as you have your vlan and subnet information you should be oaky.
Take a look here
http://www.ciscosystems.ro/en/US/docs/solutions/Enterprise/Mobility/emob30dg/HReap.html
or
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
This way you'll only have one WLAN that everyone can use whichever office they happen to be in.
e-chuah Tue, 10/20/2009 - 22:52
for the
"Employee" SSID, i mapped it to the Employee interface.
For the "Employee-H" SSID, i mapped it to a dummy interface.
That was why i need two SSID.
One possible way would be
(1) for the "Employee" SSID, at the "Advanced" tab checked the
"H-REAP local switching" checkbox.
(2) for the "Employee" SSID, map to "Employee" interface (regardless of central or local switching).
(3) for the remote site AP, configure H-REAP mode and configure SSID to vlan mapping.
(4) for the central site AP, configure Local AP mode.
(4) both central and remote sites still use the "Employee" SSID
Currently i only have one AP, so i cannot verify the above.
Can anyone confirm if this will work?
Eng Wee
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
