DDNS Update over https (ssl cert problem)
Oct 20th, 2009
I tryed to setup that my c836 router use https to send host updates crypted to members.dyndns.org but it will not work.
I used the following howto:
http://www.dyndns.com/support/kb/configuring_cisco_https.html
and selected the Root 4 - Equifax Secure eBusiness CA-1 (Base-64 encoded X.509) to copy / paste from http://www.geotrust.com/resources/root-certificates/ to my router.
show debugging
Dynamic DNS debugging is on
SSL Subsystem:
SSL Handshake Message debugging is on
SSL Error debugging is on
SSL Event debugging is on
That give me the following output:
File ../crypto/ssl/src/sslhdshk.c; Line 212 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/sslhdshk.c; Line 257 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/sslhdshk.c; Line 113 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 369 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 270 # Error -1006 [SSLPKICertValidationErr]
File ../crypto/ssl/src/ssltrspt.c; Line 250 # Error -1006 [SSLPKICertValidationErr]
00:46:24: DYNDNSUPD: Adding DNS mapping for xxx.homedns.org <=> x.x.x.x
00:46:24: HTTPDNS: Update add called for xxx.homedns.org <=> x.x.x.x
00:46:24: HTTPDNSUPD: Session ID = 0xB
00:46:24: HTTPDNSUPD: URL = 'https://user:[email protected]/nic/update?hostname=xx.homedns.org'
00:46:24: HTTPDNSUPD: Sending request
00:46:24: SSL Client Initialization Successful.
00:46:24: SSL: client hello encoded successfully.
00:46:24: SSL: write record: type: ssl handshake.
01 00 00 2F 03 00 4A DE 6A A6 3F 1E B1 BE A0 98
65 4A 76 B9 92 86 47 DB 96 E6 F3 F2 37 D4 8C 80
0E 2A 82 BF 84 48 00 00 08 00 04 00 05 00 0A 00
09 01 00
00:46:24: SSL: read record: type: ssl handshake.
02 00 00 46 03 00 4A DE 6A A6 6B F3 33 FB 80 FD
13 9D 35 01 CB C3 B5 AB 32 6C DB C3 6A 1E 51 6E
F0 17 E4 93 A8 FC 20 21 E4 27 39 C6 C0 4D 00 B9
AE FB 6D 04 91 4B BD 86 20 FD 39 C1 9E 01 9A 71
E5 72 78 81 A1 3A 19 00 04 00
00:46:24: SSL: process server_hello
00:46:24: SSL: server hello processed successfully.
sf_online Tue, 10/20/2009 - 18:04
0B 00 03 46 00 03 43 00 03 40 30 82 03 3C 30 82
02 A5 A0 03 02 01 02 02 03 0A 8E A2 30 0D 06 09
2A 86 48 86 F7 0D 01 01 05 05 00 30 4E 31 0B 30
09 06 03 55 04 06 13 02 55 53 31 10 30 0E 06 03
55 04 0A 13 07 45 71 75 69 66 61 78 31 2D 30 2B
06 03 55 04 0B 13 24 45 71 75 69 66 61 78 20 53
65 63 75 72 65 20 43 65 72 74 69 66 69 63 61 74
65 20 41 75 74 68 6F 72 69 74 79 30 1E 17 0D 30
39 30 31 32 39 31 39 31 30 31 31 5A 17 0D 31 30
30 33 30 31 31 39 31 30 31 31 5A 30 81 C6 31 0B
30 09 06 03 55 04 06 13 02 55 53 31 1B 30 19 06
03 55 04 0A 13 12 6D 65 6D 62 65 72 73 2E 64 79
6E 64 6E 73 2E 6F 72 67 31 11 30 0F 06 03 55 04
0B 13 08 38 30 34 30 31 33 36 37 31 31 30 2F 06
03 55 04 0B 13 28 53 65 65 20 77 77 77 2E 67 65
6F 74 72 75 73 74 2E 63 6F 6D 2F 72 65 73 6F 75
72 63 65 73 2F 63 70 73 20 28 63 29 30 39 31 37
30 35 06 03 55 04 0B 13 2E 44 6F 6D 61 69 6E 20
43 6F 6E 74 72 6F 6C 20 56 61 6C 69 64 61 74 65
64 20 2D 20 51 75 69 63 6B 53 53 4C 20 50 72 65
6D 69 75 6D 28 52 29 31 1B 30 19 06 03 55 04 03
13 12 6D 65 6D 62 65 72 73 2E 64 79 6E 64 6E 73
2E 6F 72 67 30 81 9F 30 0D 06 09 2A 86 48 86 F7
0D 01 01 01 05 00 03 81 8D 00 30 81 89 02 81 81
00 98 ED F7 8B AE A9 1E AC DC 22 84 61 82 09 43
72 2D 04 12 E5 1A 16 99 EF 72 7B 7A 1C 1F E0 86
EA 4D 64 D6 D2 74 9C 44 A3 9D 36 BF C0 F8 C1 3F
FC 30 D8 E9 90 FD 20 D8 93 2F CB D5 37 29 BF F7
E7 7B C7 50 99 D9 95 F9 95 72 DA ED DD 1F 7D 40
95 D3 7A D9 0D 98 F6 09 E0 7F 65 2E 23 53 86 A8
57 4E D7 16 B4 CF E5 D7 D8 6A 3E EB 4D CB 29 67
E9 10 A3 3C 05 88 E7 5D B9 F7 C3 5E FB A5 05 4C
4F 02 03 01 00 01 A3 81 AE 30 81 AB 30 0E 06 03
55 1D 0F 01 01 FF 04 04 03 02 04 F0 30 1D 06 03
55 1D 0E 04 16 04 14 72 6A EB 0D BB C8 EB BE BE
2B B6 A5 59 DD D4 D4 31 3D 80 15 30 3A 06 03 55
1D 1F 04 33 30 31 30 2F A0 2D A0 2B 86 29 68 74
74 70 3A 2F 2F 63 72 6C 2E 67 65 6F 74 72 75 73
74 2E 63 6F 6D 2F 63 72 6C 73 2F 73 65 63 75 72
65 63 61 2E 63 72 6C 30 1F 06 03 55 1D 23 04 18
30 16 80 14 48 E6 68 F9 2B D2 B2 95 D7 47 D8 23
20 10 4F 33 98 90 9F D4 30 1D 06 03 55 1D 25 04
16 30 14 06 08 2B 06 01 05 05 07 03 01 06 08 2B
06 01 05 05 07 03 02 30 0D 06 09 2A 86 48 86 F7
0D 01 01 05 05 00 03 81 81 00 37 6B 1E 31 A8 F1
47 F8 25 D9 D8 8D C2 ED E6 F5 EC 53 48 71 E1 40
6C B6 6E B0 67 88 4E 8B 3B 46 0E 3C 0D AB A8 3A
09 DC B0 50 31 FF 6D B8 A8 E1 C5 42 D5 52 0E DF
AC E5 3A C6 24 12 D8 E6 3F CF F5 05 6C 35 38 C6
9D B6 F2 15 18 CA 8D BF 46 01 8C 33 13 36 C1 BE
FF 66 39 2C E9 91 FD C6 B0 A2 B0 B0 74 27 56 61
0E E5 29 13 30 02 FD A3 DA 8E A0 D1 13 ED 14 13
AD 1F D8 10 D7 F5 1D E4 30 6A
00:46:24: SSL: process certificate
00:46:24: CRYPTO_SSL crypto_ssl_nonblocking_checkcert: Cert validation failed within PKI!
00:46:24: CRYPTO_SSL crypto_ssl_nonblocking_checkcert: The returned error code from PKI is -1006!
00:46:24: SSL: write record: type: ssl alter 02 00
00:46:24: HTTPDNSUPD: Call returned Request Aborted for update xx.homedns.org <=> x.x.x.x
00:46:24: DYNDNSUPD: Another update completed (outstanding=0, total=0)
00:46:24: HTTPDNSUPD: Clearing all session 11 info
can anyone help me please to get this fixed? i am not sure where i can start to get this working^^
Thanks!
BRIAN SEKLECKI Sun, 01/26/2014 - 00:30
I confirm similar behavior...need to be able to configure the SSL client to force accept:
004363: Jan 26 03:29:41.876 EST5EDT: 0:error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed:../VIEW_ROOT/cisco.comp/pki_ssl/src/openssl/dist/ssl/s3_clnt.c:1048:
BRIAN SEKLECKI Sun, 01/26/2014 - 01:17
Here is a copy my blog post on the topic...
I got aroud the issue with HTTPs in the DDNS client by manually creating a trustpoit and importing the certificate of the signing cert used on the HTTPs/Apache service on my domain provider (PairNIC)'s web service
Here is a simple guide of how to integrate your Cisco IOS router platform with your PairNIC-managed domain name.
This  is a useful if you are buying commodity broadband connectivity from a  hetergenous selection of regional service providers that use DHCP on a  bridged ethernet WAN (Verizon FIOS, Comcast broadband, Consolidated  Communications metro ethernet)
As you can see below,  PairNIC makes-available a REST-style HTTP WebServices URL that you can  pass simple GET-style calls to with the HTTP client in Cisco IOS  routers.
NOTE: The password field below is not your  PairNIC password, but instead, a dynamic key that is generated when you  turn on Custom DNS for your domain and enable dynamic updates
NOTE: PairNIC domains are supported.  Pair.com-managed-domains are not supported.
This works out, because you likely want to have a separate domain name for WAN DDNS updates
NOTE:  You do not need to have an A-record in place already, despite the  ambiguously named '/update' method-call below, it will actually create  records on-demand.
NOTE: I'm not sure if there is an erase/delete/destroy/remove function call -- Waiting to hear back from Pair
br00>sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M3, RELEASE SOFTWARE (fc2)
br00# conf t
ip ddns update method PairNIC
HTTP
   add  https://[PairNIC-Customer-Name]:[Domain-DDNS-Key-from-PairNIC.com]@dynamic.pairnic.com/nic/update?hostname=&myip=
interface GigabitEthernet0/1
description WAN Facing ISP
ip dhcp client client-id ascii hostname.domain.tld
! These two are likely to be ignored by your ISP's DHCP Server
! But useful to demonstrate how you could have an Cisco IOS
! DHCP server dispatch requests from Cisco IOS DHCP Clients
! in a enterprise network
ip dhcp client hostname hostname.domain.tld
ip dhcp client update dns server both
! This
ip ddns update hostname hostname.domain.tld
ip ddns update PairNIC host hostname.domain.tld
ip address dhcp
ip flow ingress
ip nat outside
ip inspect CBAC-IN-OUT out
ip virtual-reassembly in
ip access-class BogonOutside in
duplex auto
speed auto
ipv6 enable
no cdp enable
crypto map MyMap-DYMMAP
Turn on DDNS debugging to see the DDNS HTTP client functional steps:
router# debug ip ddns update
Force a release and renewal on your WAN interface (or VLAN)
br00#release dhcp gi0/1
br00#renew dhcp gi0/1
Turn on debugging to see the DDNS HTTP Client functional:
004017: Jan 26 03:09:06.110 EST5EDT: HTTPDNS: Update add called for br00.facilityCode.company.tld <=> 209.166.123.123
004018: Jan 26 03:09:06.110 EST5EDT: HTTPDNSUPD: Session ID = 0xE
004019:  Jan 26 03:09:06.110 EST5EDT: HTTPDNSUPD: URL =  'https://FOO:[email protected]/nic/update?hostname=br00.facilityCode.company.tld&myip=209.166.123.123[email protected]/nic/update?hostname=br00.facilityCode.company.tld&myip=209.166.123.123'
NOTE:  At this point, we see the HTTP CURL/WGET client in Cisco IOS doing what  it _should_ do -- however, it will fail because the SSL Library in IOS  (OpenSSL) doesnt ship with a proper set of trusted root CA Certificates
To  fix(*) this, we simply import and explicitly-trust the certificate that  signed the SSL cert used on PairNIC's cert for 'dynamic.pairnic.com'
(*) Its more of a cheap hack.  Cisco can fix by shipping a CA Cert Chain with OCSP/CRL enabled by default.
br00# conf t
br00(conf)# no crypto pki trustpoint CA-AddTrust-UserTrust
br00(conf)# crypto pki  trustpoint CA-AddTrust-UserTrust
enrollment terminal pem
revocation-check none
crl optional
br00(ca-trustpoint)#crypto pki authenticate CA-AddTrust-UserTrust
Enter the base 64 encoded CA certificate.
End with a blank line or the word "quit" on a line by itself
   [PEM Certificate here -- see below for openssl(1) command to extract on UNIX]
Trustpoint 'CA-AddTrust-UserTrust' is a subordinate CA and holds a non self signed cert
Certificate has the following attributes:
       Fingerprint MD5: F2CB531D 39AA97FF 39900B79 1319ABD4
      Fingerprint SHA1: 10189D78 180A33A9 DF7219F0 6D15FC86 5C9A6160
% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
% Certificate successfully imported
And here is functional real-world example of this working:
004675:  Jan 26 03:51:25.780 EST5EDT: DYNDNSUPD: Adding DNS mapping for  test.probikesllc.biz <=> 192.168.15.167 server 216.151.95.152
004676: Jan 26 03:51:25.780 EST5EDT: HTTPDNS: Update add called for test.probikesllc.biz <=> 192.168.15.167
004677: Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: Session ID = 0x11
004678:  Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: URL =  'https://[FOO]:[BAR]@dynamic.pairnic.com/nic/update?hostname=test.probikesllc.biz&myip=192.168.15.167'
004679: Jan 26 03:51:25.780 EST5EDT: HTTPDNSUPD: Sending request
004680: Jan 26 03:51:26.652 EST5EDT: opssl_SetPKIInfo entry
004681: Jan 26 03:51:26.652 EST5EDT: opssl_SetPKIInfo done.
004682: Jan 26 03:51:27.140 EST5EDT: opssl_SetPKIInfo entry
004683: Jan 26 03:51:27.144 EST5EDT: opssl_SetPKIInfo done.
004684: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: Response for update test.probikesllc.biz <=> 192.168.15.167
004685: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: DATA START
good 192.168.15.167 <----!! HTTP 2xx Code returns single line
004686: Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: DATA END, Status is Response data recieved, successfully
004687:  Jan 26 03:51:28.532 EST5EDT: HTTPDNSUPD: Call returned SUCCESS, update  of test.probikesllc.biz <=> 192.168.15.167 succeeded
004688: Jan 26 03:51:28.532 EST5EDT: DYNDNSUPD: Another update completed (outstanding=0, total=0)
004689: Jan 26 03:51:28.536 EST5EDT: HTTPDNSUPD: Clearing all session 17 info
004690: Jan 26 03:51:29.544 EST5EDT: DHCP: Client socket is closed
004691: Jan 26 03:51:33.464 EST5EDT: DHCPD: checking for expired leases.
$ openssl s_client -showcerts -host dynamic.pairnic.com -port 443
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
