Hierarchical QOS
billsayegh
Hi I am trying to work out how to setup QOS so that you have two shapers within the one policy and apply two separate customer classes.
The policy
Cust 1
Shape bandwidth to 20Mbps
Class Gold 20% bandwidth
Class Sliver 30% bandwidth
Class Bronze 50% bandwidth
Cust 2
Shape bandwidth to 30Mbps
Apply the policy to a single GigE sub-interface, I tried this and the config accepted it but when the traffic was passed it could not match.
I did the normal single hierarchical QOS and it all worked where you have single policy with all the classes and then assign this to a second policy default class and shape the default class however this only lets you shape a single policy.
Is it possible to create multiple policy maps at the child level and assign them to a parent policy shaping each individual child policy.
Here is the config I was testing when I do a ping no traffic is matched on access-list 99 but matched under the default-class.
class-map match-all cust1-gold
match access-group 99
class-map match-all cust2-gold
class-map match-all cust1-parent
class-map match-all cust2-parent
class-map match-all cust2-silver
class-map match-all cust1-silver
policy-map parent
class cust1-parent
shape average 10000
class cust2-parent
shape average 20000
policy-map cust2-child
class cust2-gold
bandwidth percent 40
class cust1-gold
class cust2-silver
bandwidth percent 60
policy-map cust1-child
class cust1-gold
class cust1-silver
interface Ethernet1/1.119
encapsulation dot1Q 119
ip address 143.119.2.12 255.255.255.248
service-policy output parent
access-list 99 permit any
7 Replies 7
Joseph W. Doherty
If I remember correctly, "rules" for QoS policies are a often different when applied to a subinterface. Generally a shaper is required so the policy "knows" the bandwidth to be used by the subinterface. This may explain what's happening.
Starting with 12.4(20)T, QoS policies have been enhanced also providing "HQF Multiple Policy Support", although I'm unsure this will support what you're trying to accomplish. See http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_hqf_mply_support.html and http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support_ps6441_TSD_Products_Configuration_Guide_Chapter.html for more info.
Laurent Aubert
It should work if you apply your configuration on the physical interface instead.
Also I think you should configure specific match statement at least in custx-parent class to differentiate the traffic from both customers.
Also you didn't call your child policy in your parent class.
Laurent.
Here is the updated config.
Is it possible to achieve this policy where you have two customers in a child policy attatched to a parent policy shaping each child policy.
When I ping all the traffic is going into the default-class.
class cust1-gold
class cust1-silver
class cust2-gold
class cust2-silver
policy-map parent
class cust1-parent
shape average 10000
service-policy cust1-child
class cust2-parent
shape average 20000
service-policy cust2-child
interface Ethernet1/0
ip address 192.168.80.9 255.255.255.252
half-duplex
R10#
R10#show policy-map interface
Ethernet1/0
Service-policy output: parent
Class-map: cust1-parent (match-all)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: none
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
10000/10000 2000 8000 8000 800 1000
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 0 0 0 0 no
Service-policy : cust1-child
Class-map: cust1-gold (match-all)
0 packets, 0 bytes
(depth/total drops/no-buffer drops) 0/0/0
Class-map: cust1-silver (match-all)
0 packets, 0 bytes
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
Class-map: cust2-parent (match-all)
0 packets, 0 bytes
Match: none
Traffic Shaping
20000/20000 2000 8000 8000 400 1000
- 0 0 0 0 0 no
Service-policy : cust2-child
Class-map: cust2-gold (match-all)
0 packets, 0 bytes
Class-map: cust2-silver (match-all)
0 packets, 0 bytes
0 packets, 0 bytes
Match: any
218 packets, 22135 bytes
Match: any
R10#
Laurent's suggestion does (it appears and as expected) support all the original hiearchal policy. However, also keep in mind, the policy sees more than just the original subinterface traffic (i.e you may need to adjust class-maps).
"When I ping all the traffic is going into the default-class. "
That's likely because all you class-maps but one (cust1-gold) don't have any match criteria. To get traffic into the two shaped classes, cust1-parent or cust2-parent, you'll need to match the traffic and then break it out with more matching in your subordinate child classes.
Hi many thanks for the reply.
This is a test, the only traffic I am sending is the ping to see if the class match that is why I only have one ACL to test the concept.
From my second config is the supported.
Bill
CCIE 3906
I think I have worked this out, the first class map matches the traffic and because it then feeds into the second class map that does not have a match it goes into the default class.
What I did was have a catch all match in the parent and the more secific match in the child and it worked where I was able to see all traffic in the parent and the counters for each child class incriment for the telnet and the ping.
Thanks to all those who helped.
Here is the sample config.
match access-group 199
match access-group 198
class cust1-gold
class cust1-silver
class cust2-gold
class cust2-silver
policy-map parent
class cust1-parent
shape average 10000
class cust2-parent
shape average 20000
ccess-list 198 permit tcp any any eq telnet
ccess-list 199 permit icmp any any
Ethernet1/0
37 packets, 2496 bytes
Match: access-group 99
Traffic Shaping
- 0 37 2496 0 0 no
5 packets, 570 bytes
Match: access-group 199
Queueing
Output Queue: Conversation 25
Bandwidth 40 (%)
Bandwidth 4 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
32 packets, 1926 bytes
Match: access-group 198
Queueing
Output Queue: Conversation 26
Bandwidth 60 (%)
Bandwidth 6 (kbps)Max Threshold 64 (packets)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
Match: none
Traffic Shaping
20 packets, 2049 bytes
Match: any
R10#
Hi Taking this concept one step further say if you wanted to have two customers cust 1 and cust 2, you want to give then bandwidth allocation to each of their traffic profiles and then allocate a garanteed bandwidth to the overall link.
To do this you could setup the parent class with equal shaping up to the speed of the link and then assign a percentage bandwidth to the parent.
You need the shaping command because the config does not let you put bandwidth percentage on its own in the parent without the shaping.
Is my think correct.
Here is the config using shared bandwidth in the parent class with percentages garanteed to each customer.
class cust1-gold
class cust1-silver
policy-map parent
class cust1-parent
bandwidth percent 20
shape average 10000
class cust2-parent
bandwidth percent 80
shape average 10000
class cust2-gold
class cust2-silver
Bill
