Certificate validation check with HTTPS probes
Answered Question
Oct 21st, 2009
While configuring an HTTPS probe I observe that if the certificate on the target server is expired, the ACE marks the server as PROBE-FAILED. A Wireshark trace shows that the ACE refuses an expired certificate. Here is the probe configuration :
probe https NCL_PROBE_HTTPS
description *** Server Health Probe ***
interval 5
faildetect 2
passdetect interval 5
passdetect count 2
receive 4
ssl version all
request method get url /monitor/
expect status 200 200
header User-Agent header-value "Cisco ACE-4710"
open 2
expect regex "PROBE_OK"
I can disable the expiration date validation check with an ssl parameter-map, but such a map is only applicable to the backend session (on a ssl-proxy service), but not on a https probe...
How do I make sure that my https probe can bypass the certificate validation check ?
Thank you for any help
Yves Haemmerli
Correct Answer by Syed Iftekhar Ahmed about 7 years 4 months ago
With ACE 1.x code this probe wouldn't have failed.
With ACE 2.x code, https probe check the validity of the certificate
send by server.
I don't think there is a way to change this behavior.
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 10/21/2009 - 01:22
send by server.
Syed Iftekhar Ahmed
