Restart of an ACE context
Answered Question
Oct 21st, 2009
Is it possible to restart an individual context ? Let me explain in which case I need it :
If, by mistake, I forgot to copy crypto files (key and cert) to the standby ACE, the standby ACE is in STANDBY_COLD state. Once the two file are copied on the standby machine, I have to reload it in order to achieve the STANDBY_HOT state. It would be nice to be able to restart only the specific context.
It is possible ?
Thank you
Yves Haemmerli
Correct Answer by Syed Iftekhar Ahmed about 7 years 7 months ago
There is not a way to restart an individual context.
You can try to to remove/add the keys certs on both ACEs and then go into
that context and do a "no ft auto-sync running-config" and then "ft
auto-sync running-config".
Syed Iftekhar Ahmed
Overall Rating: 5 (1 ratings)
Correct Answer
Syed Iftekhar Ahmed Wed, 10/21/2009 - 01:10
  • Blue, 1500 points or more
Syed Iftekhar Ahmed
