cisco agent desktop - issue
Oct 21st, 2009
hello, we have an issue with two agents.
when they open chat, all the time "Initializing" state, every 30 seconds, so active state every 30 seconds begins from 0, and new calls arrive to this agent
what is could be?
thank you
atalante Wed, 10/21/2009 - 01:33
run the postini and check spanlink keys in the registery.
Sergey Tregubov Thu, 10/22/2009 - 01:25
I've found this log in the event viewer in CCX Server, but can't find information about it
FCCS3008 Network communication error sending message to application . The application will be logged out.
Ryan LaFountain Thu, 10/22/2009 - 04:19
This is almost always caused by port blockage between the UCCX server and the agent desktop. The UCCX and CAD communicate over a Chat protocol for lots of things like agent state and actual Chat.
Please verify the following:
1. Windows Firewall is turned off on the CAD
2. The following telnet tests are successful:
From Chat server to agent: telnet 59020
From Chat server to supervisor: telnet 59021
From agent to Chat server: telnet 59000
From supervisor to Chat server: telnet 59000
Abdulbaseer Mohammed Thu, 10/22/2009 - 06:52
If this happening only for these two specific agents and not all agents who use chat then I suggest you move the agent to a PC that does not have issues where other agents were able to chat fine.
If it resovles then re install your CAD or even reboot should solve the issue. If these two agents are remote or vpn etc you need to look into thos products first.
Please rate appropriately if it helps.
snicklas Tue, 11/10/2009 - 08:31
this fixed my problem (CAD Sup was not checked in the win FW exception list) and saved me a lot of time, thanks a lot.
romualdgrosse Mon, 03/01/2010 - 08:52
When using CAD Chat window, I cannot see any other agent, although some are logged.
I tried the following "telnet" commands :
From agent to Chat server:         telnet 59000 ===> This works fine !
From Chat server to agent:         telnet 59020  ====> Doesn't work
From Agent to Agent :               telnet 59020                      ====> Doesn't work
This seems like the listening port is not configured properly, but I don't where to check/define it ?
Do you have any idea on this ?
Thanks in advance,
Romuald Grosse.
Nikolay Kozyrev Mon, 04/05/2010 - 03:54
Guys. I have the same problem with cisco  agent chat state  & cisco supervisor state.
The problem was with local firewall Cyber Armor. I've just retarted Cyber armor service (or restatr problem machine). All is working).
