10-21-2009 01:25 AM
Hi there, i am having a problem with a CSS 11501 machine. Problem started with a faulty compact flash slot0 that was replaced with the compact flash in slot1. since i had the configuration backed up i restored it to the new compact flash and also updated the ios version to 08.20.1.01(same with the original configuration). Also i have imported the certificates and everything works fine for a long period (1-3 Hours)i test this also by rebooting the machine. Then i reboot the machine one more time randomly and the CSS loads up with no configuration. when i do show run its blank and also show startup is blank. The certificates are all there. if i load the configuration again it will stay operational for 1-3 hours and then if i reboot it the configuaration will be lost again. Have you ever came across this problem, i need a fast resolution to the problem. i would apreciate any comment on this.
10-21-2009 08:26 AM
that's a weird one.
Never heard of it.
when you reboot with empty config, if you type 'llama' to get access to debug mode and then type 'ap_file copy c:/sg0820101/?' do you see a startup config file ?
You might have to try with d:/..../?
Could you get a 'show boot' and 'show disk' as well when there is no problem and when you just lost the config.
Thanks.
Gilles
10-21-2009 10:21 AM
Thanks for the tips Gilles. I will provide the information tomorrow as soon as i get to work.
10-21-2009 10:24 PM
Dear Gilles,
again thnks a lot for the your post. with your help i manage to find out the following: 1. i restart the CSS with a good configuration, i enter the debug mode and issue the ap_file copy c:/sg0820101/? command i get the following:
interCSS-B(debug)# ap_file copy c:/sg0820101/?
. 21 OCT 23:00:48
.. 21 OCT 22:59:38
cli 5 FEB 09:47:46
core 5 FEB 09:47:46
cvdm 5 FEB 09:47:46
images 5 FEB 09:49:46
info 5 FEB 09:49:52
log 21 OCT 22:59:44
script 5 FEB 09:50:40
web 5 FEB 09:50:46
startup-config 21 OCT 22:58:24 24306
2. I then pause for a sec to check some other things on the configuration and after a minute or 2 i run the same command "ap_file copy c:/sg0820101/?" this time i get the following:
. 21 OCT 23:00:48
.. 21 OCT 22:59:38
cli 5 FEB 09:47:46
core 5 FEB 09:47:46
cvdm 5 FEB 09:47:46
info 5 FEB 09:49:52
log 21 OCT 22:59:44
web 5 FEB 09:50:46
startup-config 21 OCT 23:05:00 0
i am waitting for you reply.
10-22-2009 07:25 AM
strange one.
What if you just configure a single interface.
Do you still see the same effect ?
You might have a script probe or command scheduler miss-programmed that erases the startup-config.
So try to go one line at a time and see when the problem occurs.
Gilles.
