username problem in cisco 7200 router
Answered Question
Oct 21st, 2009
I copied (with scp) the startup-config about my router and I modified it. I deleted old username line and i added a new. Then I send to the new startup-config to router with scp and I reloaded it. But I still login with old username.
I checked running-config and startup-config and old username line does not figure in these files. I switch off/on power, but it did not use.
Can somebody help me?
Where stores the username in Cisco filesystem? How can i view and fix it?
Some datasheed: Cisco Router 7200; Cisco IOS version 12.2(31)SB11
Thank you for the help to everybody.
Correct Answer by Richard Burts about 7 years 9 months ago
Janos
I am glad that you understand it now and that my explanation was helpful. Understanding how authentication works, especially with backup methods, can be a bit tricky but is an important thing to understand.
Rick
Overall Rating: 4.3 (3 ratings)
paolo bevilacqua Wed, 10/21/2009 - 05:27
  • Hall of Fame,
    Founding Member
Check, you might be using a radius server.
bozsikjanos Wed, 10/21/2009 - 05:41
I don't use radius server. I use local username database.
paolo bevilacqua Wed, 10/21/2009 - 06:10
  • Hall of Fame,
    Founding Member
Then there is no logical explanation to your problem.
Richard Burts Wed, 10/21/2009 - 08:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Janos
I agree with Paolo that this is very strange. Perhaps if you post the config of the router we might figure out what is causing this behavior.
Rick
bozsikjanos Wed, 10/21/2009 - 23:33
OK, I post the config of router. I cut the private datas (as ACL lists, etc..).
I think that, Somehow the IOS saved the local userdatabase to NVRAM or Flash disk. Do you say anything that I can check it? Maybe I should try erase NVRAM.
upgrade fpd auto
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service dhcp
hostname gw1
boot-start-marker
boot-end-marker
logging buffered 64000 debugging
no logging console
enable secret 5 xxxxxx
aaa new-model
aaa authentication login default local enable
aaa authorization console
aaa authorization exec default local if-authenticated
aaa session-id common
clock timezone CET 1
clock summer-time CET recurring last Sun Mar 2:00 last Sun Oct 3:00
ip subnet-zero
no ip source-route
no ip gratuitous-arps
ip icmp rate-limit unreachable 200
ip icmp rate-limit unreachable DF 200
ip spd mode aggressive
ip cef
ip tcp selective-ack
ip tcp synwait-time 5
ip tcp path-mtu-discovery
no ip domain lookup
ip domain name naviextras.com
no ip dhcp use vrf connected
no ip bootp server
ip scp server enable
call rsvp-sync
no scripting tcl init
no scripting tcl encdir
no file verify auto
username admin privilege 15 secret 5 xxxxxxx
interface Loopback0
no ip address
interface FastEthernet0/0
no ip address
shutdown
speed auto
duplex auto
interface GigabitEthernet0/0
ip address x.x.x.x 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip policy route-map PBR
media-type sfp
speed auto
duplex auto
negotiation auto
vrrp 1 ip x.x.x.x
vrrp 1 priority 110
vrrp 1 authentication text xxxx
vrrp 1 track 100 decrement 20
vrrp 1 track 101 decrement 20
vrrp 1 track 102 decrement 20
interface GigabitEthernet0/1
ip address x.x.x.x 255.255.255.252
ip access-group acl_out_to_in in
no ip redirects
no ip unreachables
no ip proxy-arp
media-type sfp
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/2
description **** Not used ****
no ip address
shutdown
speed auto
duplex auto
negotiation auto
interface GigabitEthernet0/3
no ip address
speed auto
duplex auto
negotiation auto
router bgp 65503
no synchronization
bgp router-id x.x.x.x
bgp log-neighbor-changes
network x.x.x.x mask 255.255.255.0
neighbor T-ONLINE peer-group
neighbor T-ONLINE remote-as 15545
neighbor T-ONLINE password 7 xxxxxxx
neighbor T-ONLINE version 4
neighbor T-ONLINE soft-reconfiguration inbound
neighbor T-ONLINE prefix-list t-online-in in
neighbor T-ONLINE prefix-list t-online-out out
neighbor 84.2.38.225 peer-group xxxxxx
neighbor 84.2.38.225 description **** ****
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
no cdp run
route-map PBR permit 10
match ip address 100
set ip next-hop 84.2.38.225
snmp-server community liveservice RO
control-plane
dial-peer cor custom
gatekeeper
shutdown
alias exec c conf t
alias exec s sho run
alias exec e exit
alias exec w wri
alias exec r sho ip route
alias exec i sho ip interface brief
alias exec t term mon
alias exec bgp sho ip bgp
alias exec u undeb all
line con 0
logging synchronous
history size 50
stopbits 1
line aux 0
stopbits 1
line vty 0 4
access-class vty_access in
transport input ssh
transport output ssh
line vty 5 15
transport input ssh
monitor event-trace cef ipv4 size 5000
ntp clock-period 17179796
ntp server 192.5.41.41
ntp server 148.6.0.1
ntp server 192.5.41.40
ntp server 193.67.79.202 prefer
ntp server 193.204.114.231
end
bozsikjanos Thu, 10/22/2009 - 01:45
How can I list local userdatabase on router, if it is possible?
Richard Burts Thu, 10/22/2009 - 04:20
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Janos
The config that you posted was helpful and I believe that I understand what is happening. The config includes this line:
and the effect is that when you login the router will prompt you for name and password. It will check to see if the user name you entered is in the local user database and if it is not in the local database the router will authenticate you if you used the enable password.
So my guess is that you are logging in with some other user ID and with the enable password. Is that the case?
Rick
bozsikjanos Thu, 10/22/2009 - 10:41
Hy,Rick
Yes, this is my problem.
I can login whit old user name and enable password nevertheless that I deleted it one week ago. And I don't understand it.
Can you help me? How I can delete it full?
Thank you
Richard Burts Thu, 10/22/2009 - 11:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Janos
I attempted to explain it, but apparently you did not understand my explanation. The way that you have configured it, the router will allow login with any user name as long as you use the enable password. If you do not like that then you need to change the configuration. If you change this:
to this:
then it will allow login only using the configured user name.
The router is doing exactly what the config tells it to do (and allows login using any user name if they use the enable password). If you do not like that behavior then change the config.
Rick
bozsikjanos Fri, 10/23/2009 - 10:23
Rick
I understand it by now.
I will fix it in the config of router next week.
Thank you very much for your help.
Correct Answer
Richard Burts Fri, 10/23/2009 - 11:10
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Janos
Rick
