NM-HDA to provide DSP for CM hardware resource
Answered Question
Oct 21st, 2009
I've been asked to check if an NM-HDA can be used as a hardware resource for conferencing. Everything I can find on CCO points to NO, but I'd just like to make sure.
Can anyone say if they have done this or if it is supported?
They have a 2651XM running 12.3(4).T11
Chris
Correct Answer by Jaime Valencia about 7 years 9 months ago
It's NOT supported
Prerequisites for Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html#wp1034467
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
CHRIS HABBERJAM Wed, 10/21/2009 - 13:51
Many thanks.
I'd told them it wouldn't but I really needed the confirmation, thanks.
Chris
