PPTP from DMZ
Communications
I would like some help,
I have an ipsec tunnel between the ASA and a remote site who access a machine in the DMZ, now I would like one pc on the DMZ to be able to connect outbound to an external address using the windows vpn client (pptp). I added the inspect pptp and I can connect from the inside network ok but not from the DMZ
I am obviously missing something
andrew.prince
Level 10
Level 10
You need to take a closer look at your DMZ NAT and the DMZ ACL.
HTH>
Hi Andrew,
Thanks for responding, I was obviously not paying attention. Thanks for the prompt.
np - glad to help, if you have anymore issues let us know.
