How does Pruning works
Peter Paluch Wed, 10/21/2009 - 02:57
  • Cisco Employee,
Neo,
The VTP Pruning is made by switches periodically (every 6 seconds or so) sending the VTP Join messages. Each of these messages contains a bit map in which the bit on i-th position signifies whether the VLAN number "i" is active on that switch. If a switch sends a VTP Join message to its neighbor having the i-th bit in the bit map set to 1, then that VLAN is active. If that bit is set to 0 then the VLAN is inactive and should be pruned. Simple, even naive, but working.
Best regards,
Peter
Peter Paluch Wed, 10/21/2009 - 10:47
  • Cisco Employee,
Hello Neo,
You may want to read this URL for some information regarding the VTP:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml
However, regarding the VTP Join messages, there is no public information about it - at least I could not find any. The info I have posted earlier comes from my own small sniffing and reverse-engineering of the VTP traffic.
Best regards,
Peter
