Which SFP Module for WS-C3750G-12S switch to enable port for 100MB copper
Oct 21st, 2009
Which SFP module should I use for my WS-C3750G-12S switch so I can connect a LES100 (100MB)link to the switch. The LES100 link is presented on an RJ45 cable. The WS-C3750G-12S switch has no RJ45 ports.
The LES100 link is over 500 meters.
Many Thanks
Overall Rating: 5 (1 ratings)
Joseph W. Doherty Wed, 10/21/2009 - 03:53
Assuming I'm not mistaken, I believe the SFP ports only support gig (including copper).
darrenriley5 Wed, 10/21/2009 - 06:13
That's what I thought but have just been informed by BT that it will run at 100MB.
GigabitEthernet1/0/3
Model: WS-C3750-48P
Type: 10/100/1000BaseTX SFP
Speed: 10,100,1000,auto
Duplex: half,full,auto
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
GigabitEthernet1/0/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 001e.be6b.911b (bia 001e.be6b.911b)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive not set
Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:03, output hang never
Last clearing of "show interface" counters 2w5d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
307 packets input, 23567 bytes, 0 no buffer
Received 258 broadcasts (258 multicasts)
0 watchdog, 258 multicast, 0 pause input
130 packets output, 16247 bytes, 0 underruns
iyde Wed, 10/21/2009 - 11:41
  • Silver, 250 points or more
Darren,
You will need a GLC-T for copper connection, which is what you need for RJ45.
This is what's shown here:
"Full-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP"
Edit: See this link - I hope it's not a Cisco Parner only link: http://www.cisco.com/en/US/products/hw/modules/ps5455/products_device_support_tables_list.html
