Interface Dialer Bandwidth with ATM Interface
Oct 21st, 2009
I would like to know how to automatically have correct bandwidth under my Dialer Interface who is attached to an ATM Interface.
Command bandwidth inherit doesn't work.
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode itu-dmt
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
end
interface Dialer1
bandwidth inherit
ip address negotiated
sh int atm 0
ATM0 is up, line protocol is up
Hardware is DSLSAR (with Alcatel ADSL Module)
MTU 4470 bytes, sub MTU 4470, BW 928 Kbit, DLY 2200 usec,
sh int di 1
Dialer1 is up, line protocol is up (spoofing)
Hardware is Unknown
MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec,
Bandwidth under dialer is still 56Kbit and under ATM 0 928 Kbit !!!
Paolo Bevilacqua Wed, 10/21/2009 - 04:38
  • Hall of Fame,
    Founding Member
Check virtual-access interfaces.
infomil Wed, 10/21/2009 - 04:41
Yes, interface virtual access 2 got the right bandwidth.
But I have CBWFQ applied under dialer 1 interface so I need to have the right bandwidth for this interface for CBWFQ !
Paolo Bevilacqua Wed, 10/21/2009 - 05:18
  • Hall of Fame,
    Founding Member
Since VA inherits all configuration from dialer, everything will work as supposed.
Please remember to rate useful posts with the scrollbox below.
infomil Wed, 10/21/2009 - 05:30
Sorry but VA inherit everything but queueing strategy, I've got Dialer 1 with Class-based queueing and VA2 with fifo queueing ?
At least, my question is : is there a command to have bandwidth under dialer1 automatically equal to atm bandwidth ???
Paolo Bevilacqua Wed, 10/21/2009 - 05:34
  • Hall of Fame,
    Founding Member
That could happen because the default PVC traffic category (UBR) does not allow QoS.
Beside that, it is working as designed, nothing will ever change any configuration under dialer.
