Asian language subject in M-query
Oct 21st, 2009
SENDER: [email protected]
RECIPIENT: [email protected]
SUBJECT: \\xa1i\\xae\\xc9\\xa5N\\xbe\\xc7\\xb0\\xf3\\xa1j\\xb3\\xb3\\xb0\\xfb\\xbb\\xf6\\ ... \\xa1i\\xae\\xc9\\xa5N\\xbe\\xc7\\xb0\\xf3\\xa1j\\xb3\\xb3\\xb0\\xfb\\xbb\\xf6\\...
The subject is not RFC2047 compliant. I want to find an easy way to decode them.
The 2nd question,
when it is RFC2047 compliant. Then if you click the "subject" inside the query result. You practically add the "subject" as a condition to your previous query.
Strange thing is that it will now match nothing. (but it was matching when I do not add subject as a condition).
