I cannot acces asdm webpage
Oct 21st, 2009
i just new asa5510 and configure it with these give inside and outside interfaces ip and security level commands
and commands
http server enable
http 0 0 iside
but i cannot access asdm webpage
Panos Kampanakis Wed, 10/21/2009 - 05:23
Did you create a crypto key (crypto key generate rsa modul 1024)?
Are you using http or https to access to page? Try https.
I hope it helps.
wael.kamal Wed, 10/21/2009 - 05:42
the customer asked to change the asa name
ASA_XX# this may cuase i cannot access asa because certificate parameters change if so how can i remove the default certificate and creat new one
