Auto config archive of FWSM with LMS 3.2
Oct 21st, 2009
  • Bronze, 100 points or more
is there a way to archive the config files of a FWSM automatically such as from a switch?
I looked for syslog messages like I get them from switches (%SYS-5-CONFIG). But I can't find anything like that.
Severity level is notification on FWSM.
Is there a way to trigger Config fetch in RME?
Thanks a lot!
yjdabear Wed, 10/21/2009 - 05:38
  • Gold, 750 points or more
The default "Config Fetch" under RME - Tools - Syslog - Automated Actions has an entry "PIX-*-5-111005:*". Extrapolating from that, perhaps you want to edit "Config Fetch" or build your own AA by adding in "FWSM-*-5-111005:*", and possibly ""ASA-*-5-111005:*" for the sake of being comprehensive.
http://www.cisco.com/en/US/docs/security/fwsm/fwsm23/system/message/fsmemsgs.html#wp1038950
Error Message %FWSM-5-111005: IP_address end configuration: OK
Explanation This message is logged when you exit the configuration mode. The IP_address value indicates whether the login was made at the console port or through a Telnet connection.
Recommended Action None required.
