not able to ping
zeuscyril
Level 4
Level 4
hi friends,
i configured site to site vpn between two sites ,one side having cisco 2811 and the other side juniper firewall.but the tunnel is up ,but i am not able to ping the remote lan
and my sh crypto isakmp sa showing
state-QM_IDLE and active
but not able to ping
help me out
vincent.monnier
You should payed attention from which IP your are sending the ICMP echo request.
The source IP address of your testing packets should be in the participating networks of the IKE phase2.
For exemple :
On your 2811 use the following command
ping destination_ip_add source 2811_lan_ip_add
or
ping destination_ip_add source lan_interface_name
on your Juniper (if screenOS) use :
ping destination_ip_add from lan_interface_name
