Catalyst 2950 default IP Address?
Oct 21st, 2009
I have a site with about 8 Catalyst 2950s, all connnected with fibre. My problem is that I don't know if they have been enabled with an IP address. I have used the Network Assistant and searched my subnet without luck. It may be on another subnet. I don't have a rollover cable handy to check a box through the console.
Does anyone know if the Catalyst 2950 has a default IP address?
Does anyone have any other ideas which might help me?
Jon Marshall Wed, 10/21/2009 - 06:28
No they don't come with a default IP.
If CDP is enabled you could try "sh cdp neigh det" on each switch.
