L2TPv3 help required
Oct 21st, 2009
Good day all
I'm having an issue implementing L2TPv3 between two sites. I am issuing the xconnect command to the subinterface which I want to connect, and I get this error:
"Incompatible with ip address command on Fa0/0.2"
Now I need the IP on the interface as hosts point to it for routing purposes. Is there a way to work around this problem?
Giuseppe Larosa Wed, 10/21/2009 - 06:47
  • Hall of Fame,
    Founding Member
Hello Jason,
unfortunately you would need a second subinterface using same Vlan-id on a different Fastethernet port to provide both L2 and L3 services to the same vlan.
something like
int fas0/0.2
enc dot1q 2
ip address 10.2.2.1 255.255.255.0
int fas0/1.2
enc dot1q 2
no ip address
xconnect ...
with both interfaces connected to L2 trunk ports of an external LAN switch.
Hope to help
Giuseppe
osiristrading Wed, 10/21/2009 - 08:44
OK I've managed to get the commands entered, but I cannot ping (or even ARP) for hosts the other side of the link.
One the one side of the link I am running the xconnect on a subinterface, but on the other the xconnect is on the main interface (there are no subinterfaces). Could this have something to do with the problem?
Giuseppe Larosa Wed, 10/21/2009 - 08:46
  • Hall of Fame,
    Founding Member
Hello Jason,
I would say yes
try to have xconnect on subif also on the other site.
Hope to help
Giuseppe
