QoS policy - check my math :)
John Blakley
All,
I created the following policy:
policy-map DR
class BRANCHES
bandwidth percent 12
random-detect
police 17408000 conform-action transmit exceed-action drop
class DRTRAFFIC
bandwidth percent 60
class DALLAS
bandwidth percent 3
police 3072000 conform-action transmit exceed-action drop
class class-default
fair-queue
random-detect
This is on 100Mb connection between two locations. I want Branches to get 12mb minimum and police at 17Mb. The DR site I want to guarantee 60Mb, and the Dallas location I want to guarantee 3Mb but no more than 3Mb. Does the above look like it would work?
John
HTH, John *** Please rate all useful posts ***
2 Accepted Solutions
The bandwidth statement guarantees a minimum, i.e. you shouldn't need to police or shape unless you really need to also cap the bandwidth.
Yes, shape should work in lieu of police.
What I'm suggesting, if you provide minimum bandwidth guarantees for all traffic that needs it, you shouldn't need to cap any traffic. The whole idea of providing traffic minimum bandwidth guarantees is so they continue to work as needed even when the link is saturated.
I often work with WAN links that run VoIP, vidconferencing, mission critical business apps, normal business apps and system backups. Such links might run at 100% utilization (generally due to system backups) for hours (and during normal business hours), yet QoS allows all the other apps to function as if the backup wasn't running.
If your QoS can insure traffic does obtain the proportion of bandwidth the application needs when there's congestion, there generally little need to cap bandwidth for any traffic.
So you might try:
policy-map TOGO
class SENDDALLAS
bandwidth percent 1
class BRANCHES
bandwidth percent 7
class DRTRAFFIC
bandwidth percent 30
class class-default
bandwidth percent 10
(NB: if your wondering about the reduced percentages, it's the ratios that are really used [they set flow weights], and it also avoids busting the reserved bandwidth setting [remaining percent is another nicer option - if supported by the IOS] along with be easier to use on other bandwidth capacity links.)
[edit]
PS:
BTW, with QoS link "saturation" often isn't the issue it is without QoS.
11 Replies 11
Giuseppe Larosa
Hello John,
I've never combined police action with bandwidth action on same policy-map.
I would police on ingress LAN interfaces if really needed with different policy-maps applied inbound on those interfaces.
On outgoing "WAN" interface I would apply a scheduler.
this would provide the advantage of an easier reading of sh policy-map interface type x/y or equivalent SNMP MIB variables.
CBWFQ is elastic in nature and allows unused resources to be used by other traffic classes.
So I don't usually consider to police on outbound interface.
You could for example use a priority command for DR traffic just to make an example, to be sure it will not compete with other traffic classes when the link is fully used.
Edit:
I've realized that I didn't answered your question about the math.
From this point of view it looks like correct (not sure if rates may have to be multiple of 64 kbps or other constraints but these are platform dependent).
Hope to help
Giuseppe
Thanks Giuseppe. So I should police inbound on the LAN side on both sides of the link to the max bandwidth that I want to allow, and then use RED or something like that on the outside to match the transmitted traffic?
Joseph W. Doherty
Would it work as intended? Possibly not because on many platforms/IOSs, FQ within class-default can disturb other class bandwidth allocations. This can be addressed by not using FQ within class-default or using 12.4(20)T or later HQF QoS.
Otherwise, like Giuseppe, I would recommend against using a policer. If you guarantee class minimums, why cap a class if the bandwidth is otherwise available and not being used? If you do need to cap traffic, I often prefer a shaper. Also, if your IOS supports it, you might see if the policer supports percentages rather than absolute values.
Joseph,
If I want to guarantee the traffic for a minimum, should I shape instead of the policing, and would shape work in the same policy map?
John
Does this one look better?
policy-map TOGO
class SENDDALLAS
shape average 3072000
class BRANCHES
shape average 17408000
class DRTRAFFIC
priority percent 60
class class-default
policy-map MARKTRAFFIC
class DALLAS
set dscp af23
int fa0/0.175
service input MARKTRAFFIC
int fa0/1
service output TOGO
Thanks!
No, for a several reasons. You should still use the bandwidth statement to define the minimum bandwidth. Removing the FQ statement within class-default, on many platforms, it's still FQ. I'm not too keen placing DR traffic into LLQ.
How would you treat the DR traffic? I need to keep the DR traffic from saturating the link, but at the same time I need to make sure it gets a minimum to replicate correctly. This is a continuation of what you helped me with a couple of weeks ago.
John
The minimum bandwidth for correct replication is guaranteed by the class bandwidth.
As to also keeping such replication traffic from saturating the link, that could be done using a policer or shaper, as you've been thinking, but the better alternative is to guarantee other traffic the bandwidth it needs.
If we guarantee DR traffic 60% and guarantee other traffic the other 40%, DR can "saturate" the link in that it might use 100%, yet this should only be seen if other traffic doesn't want that bandwidth. If other traffic does want bandwidth, DR will be pushed aside such that other traffic gets its guaranteed 40%. If other traffic wants more than its guarantee, it can have it, again provided DR isn't using it. So you might also see other traffic "saturate" the link, again though, only if DR isn't demanding any bandwidth.
What you commonly see with bandwidth intensive traffic vs. non-bandwidth intensive, is bandwidth intensive traffic getting more than its guarantee. It is, again though, because the other traffic doesn't want its guaranteed bandwidth.
If all traffic types (classes) wanted to "saturate" the link, you should see each running at its guaranteed proportion of bandwidth.
Joseph,
So, bear with me, if I'm reading this right, I should keep the bandwidth statements for the minimums, shape to the maximums, and just shape to a maximum for DR?
Would this work:
policy-map TOGO
class SENDDALLAS
bandwidth 2048
class BRANCHES
bandwidth 15360
class DRTRAFFIC
shape average 76800000
bandwidth 61440000
class class-default
Would the above be better? Would the above would set aside the traffic for the branches and have them work correctly, but not saturate the link, and the DR traffic "should" continue working normally? I'm still setting aside 60Mb for DR traffic.
Thanks for sticking with me on this Joseph. =)
John
So you might try:
policy-map TOGO
class SENDDALLAS
bandwidth percent 1
class BRANCHES
bandwidth percent 7
class DRTRAFFIC
class class-default
[edit]
PS:
