EIGRP not working
Oct 21st, 2009
I have the follow Cisco switch:
WIENEU_CORE#sho ver
Cisco IOS Software, C3550 Software (C3550-IPBASE-M), Version 12.2(25)SEB4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 30-Aug-05 13:14 by yenanh
ROM: Bootstrap program is C3550 boot loader
WIENEU_CORE uptime is 3 years, 5 weeks, 5 days, 1 hour, 34 minutes
System restarted at 16:10:29 GMT Tue Sep 12 2006
System image file is "flash:c3550-ipbase-mz.122-25.SEB4/c3550-ipbase-mz.122-25.SEB4.bin"
Cisco WS-C3550-48 (PowerPC) processor (revision S0) with 65526K/8192K bytes of memory.
Processor board ID CAT1012Z3P5
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 4 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 5 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 6 has 1 Gigabit Ethernet/IEEE 802.3 interface
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:17:94:23:1E:00
Motherboard assembly number: 73-5701-10
Power supply part number: 34-0967-03
Motherboard serial number: CAT10120FQQ
Power supply serial number: DTH1005895S
Model revision number: S0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT1012Z3P5
Configuration register is 0x10F
I have configured routing on, but when I try to configure eigrp i get the message 'Protocol not in this image'.
Can I upgrade or does the protocol not work on this device?
Overall Rating: 4 (1 ratings)
Jon Marshall Wed, 10/21/2009 - 08:19
Raj
EIGRP is not supported in the SMI (Base) image. You need to upgrade the image to the EMI version. This can be done on the same switch but there will be a cost to upgrading.
Jon
RVirdi Thu, 10/22/2009 - 00:09
Thanks Jon.
That's exactly the answer I was hoping for.
