Log SNMP Information
Oct 21st, 2009
Hello everyone,
Is there a way to log SNMP information to the local router and download it or access it at a later date? Looking to capture bandwith and CPU utilization as well as any error messages, etc but won't have an SNMP server set up for about a week.
Thanks in advance! All replies rated
Overall Rating: 4.8 (3 ratings)
Lucien Avramov Wed, 10/21/2009 - 09:20
There is no way to log the SNMP information and see it later about the counters as this is real time information.
Do you have a NAM module in your network?
angel-moon Wed, 10/21/2009 - 09:23
Thanks. No NAM. What's the most I can do to capture information then? Just enable logging buffered?
Lucien Avramov Wed, 10/21/2009 - 11:08
Logging will capture you to a syslog the console messages. That wont have the counters you are looking for.
I was more thinking that you could run an rsh script from a server or linux end device and get periodically the show interface outputs for example. For that you need to enable rcmd on the router as per :
Or you could enable NBAR on the router and periodically over RSH get the show ip nbar protocol-discovery output that will have the 5 minutes counters per protocol.
Protocol counters also do come handy when you monitor traffic, it gives you a supplemental picture of what's happening.
Example of NBAR output:
Last clearing of "show ip nbar protocol-discovery" counters 4w5d
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
http 1865324 1148110
2399109004 620270044
0 0
3970000 694000
bittorrent 348044 437191
300634149 42385104
0 0
1769000 58000
skype 725721 677595
298862503 115311935
0 0
579000 428000
edonkey 31721 18948
41515699 1545974
0 0
488000 11000
secure-http 229475 217413
171282588 54029522
0 0
294000 105000
h323 91130 117130
96943577 10974664
0 0
115000 9000
secure-imap 37244 52555
23380550 4683673
0 0
75000 7000
