Win7 - AnyConnect Client and Cisco VPN Client ?
Oct 21st, 2009
Perhaps someone knows;
Can The AnyConnect 2.3.0254 client and the Cisco Ipsec client be installed on the same Win7 machine without conflict ?
Since it's not my machine, It's best to ask advice before trying.
Dean H.
JORGE RODRIGUEZ Wed, 10/21/2009 - 12:05
Dean, you can have both clients installed on the same machine, I do speak for Windows Vista where I either use Annyconnect client or Cisco VPN client, but have not come across any threads out there indicating conflits warnings in Windows 7.
The Cisco VPN client is supported on the 32bit platform of WIndows 7(NOT the 64bit) so be aware of this. I would suggest you to go over Releas notes for each client and look at opened Caveats to see if there is anything reported pertaining to your question.
Cisco VPN client latest version release notes
AnnyConnect client latest version release notes
dheinen Wed, 10/21/2009 - 12:29
Thanks ! Our support team also replied with essentially the same answer.
Dean H.
dheinen Thu, 10/22/2009 - 12:27
True, but not IPSec capabilities, only SSL. AnyConnect seems to be a poor name for a VPN client that cannot connect IPSec.
