Need to a Get Reporting Statis to a script.
Oct 21st, 2009
Hello, I'm new at this. I would like to do the recording and have the system say what number the caller is in queue. Can someone give me example of a script? or give me some pointers.
Abdulbaseer Mohammed Fri, 10/23/2009 - 07:33
  • Silver, 250 points or more
Destiny,
You can do this in 3 step process:
Get reporting stat - put this in a variable
create generated prompt ordinal
create container prompt with your desired prompt
play the promt.
Attached a screen shot of some of my designed scripts, this should help.
please rate helpful posts.
Baseer.
