ASA 5540 7.2(2) crash and reboot
Today i have a problem with a Cisco ASA 5540, suddenly it crash and rebooted. All that i see is the 99% utilization of the CPU in the crashinfo file.
The device was working normally, with no configuration or hardware changes
I attach the crash-info file
Jatin Katyal
After analyzing the crashinfo, it looks like that you ate hitting this bug
CSCsk33743 High CPU followed by reload with Thread Name: IP Address Assign
You may check this here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk33743
This is one-time crash so issue is Unreproducible.
JK
Plz rate helpful posts-
~Jatin
Thanks for your help
Can you tell me if exist an IOS version more stable that the version 7.2(2)?
This to consider the possibility of the update in case of a new crash.
You may go for
8.0.4 (45)
Much stable than 8.2.1
JK
~Jatin
