Password Recovery in Cisco 4507 catalyst
Oct 21st, 2009
Hi All, I want to recover the password of catalyst 4507 switch which is connected to a 6509 catalyst and AAA server is active. I tried to change the config register to 0x2141 but again on resetting, it is asking the username for authentication instead of Switch>. Please help me.
rite2anil Fri, 10/23/2009 - 00:37
Hi Giuseppe
I am following the same procedure but still not getting the same prompt i.e Switch>. I am attaching the capture text for your ref. Pleasse help.
Giuseppe Larosa Fri, 10/23/2009 - 00:44
  • Hall of Fame,
    Founding Member
Hello Anil,
the system is presenting a username/pwd login like it has loaded the configuration.
I see you have two supervisors installed
I would repeat the procedure with only one supervisor inserted
Hope to help
Giuseppe
