L2TPV3 Psuedowire 6509
Oct 22nd, 2009
I m trying to create a psuedowire between 6509 and 3845 which are connected by means of IPV4 network. 6509 is running with code as 12.33SXI and i found that the encapsulation method under pseudowire class is only mpls not the l2tp..
If i configure the psuedowire class with encapsulation with mpls and network between 6509 and 3845 is not mpls enabled...will it work..?? is there any way to set the encapsulation to l2tp instead of mpls ?
if not any workaround ..
francisco_1 Thu, 10/22/2009 - 01:56
you need mpls label switching to use mpls encapsulation. For cat6500 i dont think the 12.33SXI suuport L2TPV3 VPN.
use the Cisco Feature Navigator to search for the feature you need for you switch. This tool is very useful and i encourage people to use it...
