Changing per-user idle and absolute timeouts using TACACS+.
Jatin Katyal Thu, 10/22/2009 - 03:40
Hi Andrea,
The PIX timeout uauth command controls how often re-authentication is required. If TACACS+ authentication/authorization is on, this is controlled on a peruser basis.
To configure timeout and idle timeout on the ACS Server using TACACS+, follow these steps:
Step 1. On CS ACS GUI, from left Menu navigation, click on Group Setup, choose the Group, and click on Edit.
Step 2. On the Group Configuration page, select TACACS+ from the Jump To drop-down menu.
Step 3. Check the Shell (Exec) box.
Step 4. Check Idle time and enter a value of 2.
Step 5. Check the Timeout box and enter a value of 1.
Step 6. Click the Submit+Restart button.
Note: You must have the authorization turned on for timeout and idle timeout to work properly.
Plz rate helpful posts-
