IOS IPS - only 3 Signatures...
Oct 22nd, 2009
I have a 2801 running Advanced IP Services version 12.4(24)T.
I have enabled the IOS_IPS feature but in looking at the IP IPS ALL command I see only 3 signatures enabled.
I was reading the docs and was going to download the 128.SDF sinature file to the router - but it is too large for my 64Meg of flash.
I expected to see a SDF file somewhere in the flash - but I cannot find it.
What should I be doing at a minimum to get basic IPS running?
Why do all the Micro Engine Signatures show INACTIVE?
Collin Clark Fri, 10/23/2009 - 06:21
The base SDF signature file has a very limited signature base. You'll need to increase your flash if plan to put this into production. You probably have a directory in flash where the pkg files are stored. Here's a great guide that I used to get IPS working.
Hope that helps.
